excel file to text in hex format 16 places per row
Hi R,
@RHutchings wrote:
I started, but something has changed on the website and I need to get used to the new format. That said. I have these numbers in Excel, let's just say 60 40 0 60 0 0 40 60 40 0 60 0 0 40 60 40 0 60 0 0 40 60 40 0 60 0 0 40 60 40 0 60 0 0 40. I want them to be like this. 60 40 00 60 00 00 40 60 40 00 60 00 00 40 60 40 00 60 00 00 40 60 40 00 60 00 00 40 60 40 00 60 00 00 40
Just set the cell format to "00" in Excel, so it will show numbers using two digits with leading zeros...
Message 11 of 20
(1,256 Views)
Yes, if this were an Excel forum, that would be the solution. 😄
Message 12 of 20
(1,245 Views)
Hi Christian,
Well, the requirement was "Which ever is easier I guess."... 😄
Message 13 of 20
(1,241 Views)
@GerdW wrote:
Hi Christian,
Well, sparse question are ambiguous and we don't really know the backstory. If (big if!) the data originated in LabVIEW and a LabVIEW program is used to write that malformatted excel file, it would be a detour to even use excel. 😄
Message 14 of 20
(1,233 Views)
That got me part way there, thank you. Now to arrange them into 16 columns.
Message 15 of 20
(1,221 Views)
What was "that" that got you part way there? (I recommend to quote relevant section of the post you are replying to as I just did above!)
I already showed you how to reshape the data into 16 columns. Have you tried?
This will fill rows first. If you want to fill columns first, a little bit mode code is needed. (e.g. Swap the size inputs to "reshape array" and transpose afterwards)
(I am not sure if there is an easy solution within excel. Never use it. 😉 )
Message 16 of 20
(1,217 Views)
Sorry, no I didn't see that. Now we're getting somewhere.
Message 17 of 20
(1,206 Views)
What are the vis you are using?
Message 18 of 20
(1,197 Views)
Accepted by topic author RHutchings
  1. spreadsheet string to array (type=1D U8 array, format=%d, delimiter <space>)
  2. array size, quotient&remainder, sign, add, I32 diagram constant of "16"
  3. reshape array
  4. spreadsheet string to array
Message 19 of 20
(1,193 Views)
In the end none of this was used but I did learn a bit from all the posts.
Message 20 of 20
(1,136 Views)
