excel graph Legend
Can anybody explain me how to do the Excel graph Legend contents in top to down order. By default i am getting as Left to right order.
(2,944 Views)
Hi srinath,
               see the link:-
               http://forums.ni.com/t5/LabVIEW/Excel-Graph-Legend-Formatting-Report-Generation-Tool/td-p/1929939
               No need to create new thread stick with  your first one.
Thanks as kudos only:)
(2,940 Views)
Hi Daniel,
Whatever you are sending the link  it is good job but my problem is if you open the above link in that open the following VI and do the following modifications.
increase the Row header size to 64
Add Excel Format Image.vi before the Get ActiveX References.vi and set Height to 6,Width to 9
Legend width to 168
Legend Font Size to 8
Now u can see the excel graph output legend  Header contents are displayed in Left to Right Order.
But i need to display order Top to Down.
Excel_Add Graph and Format Legend.vi 38 KB
Plase check this ......
(2,933 Views)
