how to read the date and time information of a file by labview
how to read the date and time information of a file by labview? for example, created time and modified time.
(4,201 Views)
Accepted by topic author Jimmyzeng
The similar question had been discussed here (it's old thread but seems still valid):
http://forums.ni.com/t5/LabVIEW/file-date-created/td-p/109836
TailOfGon
Certified LabVIEW Architect 2013
(4,192 Views)
if you need to know the last modification date of file:-
"Functions->File I/O->Advanced File Functions->File/Directory Info.vi"
This vi returns the value of file's last modification date. This is returned as U32 number. To see it in MM/DD/YY format you must create the indicator, right-click on it and select "Format & Precision" item from drop-down menu. Then select "Time and Date" format there.
Thanks as kudos only:)
(4,190 Views)
Hi Tail,
           I also refferd that I think it suits with what OP was asking.
(4,189 Views)
