excel
Hello Guys
I need a help please, i'm working in a test bentch and i have several large excell spreadsheets of data and i need to merge into one spreadsheet using labview. Can anyone tell's me how to do it?
Thanks, Hugs
(3,941 Views)
Hi Rui,
you need to read each of your "several excel spreadsheets" and then save the data in "one big spreadsheet". Sounds pretty straight-forward…
What exactly is the problem? Where are you stuck?
(3,937 Views)
Hello GerdW
I'm stuck because i never did it before and i work in labview for one year. i'll try to do has you told. If you send me an example, i appreciate it.
Thanks a lot
(3,932 Views)
Hi Rui,
when you use the RGT (ReportGenerationToolkit) you will have a lot of examples in the LabVIEW example finder.
Try those!
(3,923 Views)
Here is an example using the Report Generation Toolkit that I posted about a year ago ...
Bob Schor
(3,888 Views)
