exe building makes small file
The only solution i found so far is to switch to x64. There are quite a few drawbacks like unsupported cRIO (hence have to keep two versions of LV) but at least project builds 100% of the time. No 144KB exe files, no failed builds.
www.xinstruments.com - Custom Software for Industrial Automation
www.hdrconverter.com - Picture processing made easy
Message 41 of 55
(1,601 Views)
If only the development system was 64 bit but still able to build 32 bit applications, I'd switch in a heartbeat.
Is there any way to dig deeper into what that invoke node does?
What code does it call? Is it in some dll?
Message 42 of 55
(1,595 Views)
IIRC LV22 64 bit supports cRIO.
Message 43 of 55
(1,589 Views)
Why? Why do you need 32 bit executables when it works on 64 bit?
Are you using LV dlls in external epplications?
No. Compiled code (LV internals). Maybe, but undocumented for sure.
Message 44 of 55
(1,584 Views)
Has anyone gotten any help from NI on this issue? I reached out to technical support but wasn't able to get beyond trivial support suggestions.
Message 45 of 55
(1,565 Views)
While LV22 does support cRIO, which is very nice, ethercat doesn't seem to have 64 bit support, only offering 32 bit.  That's really the only reason honestly
Message 46 of 55
(1,555 Views)
Aside from non-supported Ethercat we had another issue: RT/FPGA application which was running fine in 32bit crashes regularly if built and run in x64. It means now we have to support two source codes. Very annoying.
NI support wasn't helpful too much. I can understand it in a way. They need a source code to test. But in reality you can just generate bunch of random VIs (i assume) and create project which pushes 3.5GB during build time and 100+MB in exe size and get same results (failed builds or builds which end up with 144KB file).
Message 47 of 55
(1,523 Views)
That's not mentioned here at all:
NI-Industrial Communications for EtherCAT and LabVIEW Compatibility - NI
I guess that doesn't mean much, limitations of products are automatically removed before publishing online. Or so it always seems to me.
It is mentioned here though (NI-Industrial Communications for EtherCAT (NI-ECAT) is not supported, NI-Industrial Communications for EtherCAT is?):
NI Product Compatibility for Microsoft Windows 10 - NI
On Windows 11 NI-Industrial Communications for EtherCAT (NI-ECAT) is not supported at all (32 or 64 bit)
NI Product Compatibility for Microsoft Windows 11 - NI
Seems like NI-Industrial Communications for EtherCAT (NI-ECAT) is being deprecated.
Message 48 of 55
(1,505 Views)
And they should hurry.
I'm sure 32 bit will be unsupported at some point in the not to distant future.
And it should, but not until 64 bit works (completely and for everyone).
Message 49 of 55
(1,495 Views)
IIRC our main issue was that we use 3rd party dlls which are 32 bit, and I was told those won't work in a 64 bit application.
Message 50 of 55
(1,493 Views)
