exe encounter problem
I tried all of these options you've given me, and downloaded the exe to try the setup, and I still get the error. Can you try any of the methods you offered on a clean machine and see which of them work best for you, as well as provide me with some more instructions on how to install? I've tried several different methods to install all of these dlls, yet for the life of me I still can't get it to work! Thanks for your patience!
Jeremy L.
Jeremy L.
Message 21 of 25
(1,489 Views)
Hey, sorry and thank you so much for your perseverance. Hm....I just did this recently (two days ago) on a new machine. All I did was install the program and it automatically puts the dlls in C:\Program Files folder, except for deplevaldll.dll. Then I register all the dlls (ADIEvalInt.dll, deplevaldll.dll, DEPLEvalTools.dll, SAX2.DLL, and DEPLDevDriver.dll) except for Drvx40.dll and the Dxusb10.dll that you need to copy and put in windows/system32 folder. When I installed the program two days ago, they were already in the system folder without me copying them. It works for me. I am a coop here and today is my last day, but I wil
l be back in January to troubleshoot this problem. So if you come up with the solution, can you try and email me at NCAnn83@aol.com? Thanks.
Message 22 of 25
(1,489 Views)
Sorry it's taking so long here. I still can't get it to run on my machine. What I've decided to do is move to another test machine and see if I can get it installed there. If it works there, then I'll just continue troubleshooting over there. I'll definitely email you and let you know what I find out. Thanks for your help!
Jeremy L.
Jeremy L.
Message 23 of 25
(1,489 Views)
I also encountered a similar problem right now. I made a program using Labwindows, using another dll, and GPIB/GPIB 488.2 Library & Word2000.fp instrument files. I met two issues:
1) My exe program runs well for almost 50 hours and then was stopped with error message: "X has encountered a problem and needs to close...". In the Error signature appeared the dll that I used in my program in ModName.
2) In UI of the program, there is a button to create Report (making a graph, put a table of results into the doc file, and then insert the graph after the table). If I click that button, the same error message as above appeared. In the Error signature appeared cvirte.dll in ModName.
I captured these two errors in the attached files.
How can I identify where the bug is? and How should I do to solve this problem?
Thank you very much.
Message 24 of 25
(1,234 Views)
It's silly to hijack a 6 year old thread and it's silly to hijack a completely unrelated one. This is the LabVIEW board. LabWindows/CVI has it's own.
Message Edited by Dennis Knutson on 03-07-2010 08:05 PM
Message 25 of 25
(1,231 Views)
