execute vi
when I ve putted the vi into the "include" section, the error has disappeared !
I m persuadated that the problem is that the front panel is removed when building! but how to avoid that?!
Message 11 of 13
(971 Views)
there is no screenshot
Message 12 of 13
(970 Views)
If you place the VIs in the upper, "Startup VIs" section then, by definition, the front panel is not removed since these VIs are considered "top-level". That's why it works when you add it to this list. It works because the front panel is not removed, as the default setting is to not remove the front panel for VIs in this list. Adding the VIs to the bottom "Always Included" section would do the same thing since the same default is applied to this list. However, this is a work-around since the subVI is already included since it's being called as a subVI.
Sorry. Attached this time.
Message 13 of 13
(965 Views)
