execution time too low
I was trying to measure the execution time. The rate is 1KS/s per channel and the samples to read is 100 per channel in a for loop of 10. The time should be around 1000ms, but it's only 500-600ms. And when I changed the rate/numbers of samples, the execution time doesn't change..... how could this happen?
Message 1 of 9
(4,239 Views)
whats the device?
Message 2 of 9
(4,237 Views)
NI-USB 6009
Message 3 of 9
(4,234 Views)
Accepted by JudeLi
Well,
Clearing the task inside the loop is something of a problem.  (The error handler should jump up on the second iteration)
Message 4 of 9
(4,223 Views)
I've tried to drag the clear task out of the loop but every time I did it, it ended up in a broken wire saying that the soure is a 1-D array of  DAQmx event and the type of sink is DAQmx event.....
Message 5 of 9
(4,216 Views)
Because it put in an auto-indexing tunnel.  You need to right-click on the tunnel and disable auto-indexing.
Message 6 of 9
(4,213 Views)
You can right-click on the output tunnel and tell it to not auto index.  But even better would be to use shift registers just in case you tell that FOR loop to run 0 times.
Message 7 of 9
(4,210 Views)
It works! Thank you very much!
Message 8 of 9
(4,207 Views)
It's amazing! I've never ever thought the shift register can be used like that! Thanks a lot!
Message 9 of 9
(4,200 Views)
