exponentaial curve fitting
  The exponentaial model for curve fitting in LabVIEW is y=a*exp(b*x). Is it possible to curve fit a model y=a-a*exp(b*-x). One example of this model is the voltage of the capacitor of a RC circuit when applied a DC voltage.
   Thanks for help!
   Tom
(3,720 Views)
Accepted by tom_z
Yes, just use the generic nonlinear curve fit and write your own model. 😉
(3,699 Views)
Thanks! It works.
(3,672 Views)
Hi Altenbach & Tom_z
Very pleased to find this old discussion. Just what I needed to achieve on a project I am working on, and after reading this and a bit of effort on the model it works a treat.
One thought. This vi has two polymorphic methods, manually selected. You can either use the function model method or the function string method. I got the function model method working, but when I tried the function string method I couldn't make it work. Is it coincidence that all the examples use the function model method?
Best Regards,
Bandit.
(3,249 Views)
