exponential time component
hi everyone:
I have a problem on implementing the following equation on labview (exp[j 2 pi F t ]), as we know that
 exp[j 2 pi F t ]=cos(2 pi F t) +j sin(2 pi F t), I have a problem on entering the parameter (t) to the EXP block on labview.
(3,569 Views)
Accepted by topic author ASHLY19
I am not exactly sure what you are trying to do, but it seems to me that you just need to change the constant to a control. If you want to run the equation with a range of t values, put what you have into a for loop and index in an array of t values.
(3,538 Views)
Hi Ashly,
If you wish to use exp(x) = cos(x) + j sen(x), I recommend to use Exponential (Arg) - 1 (G Dataflow).
Happy new year!
(3,520 Views)
