export from ring control
Is it possible to export the list of items in a ring control or conversely import a list into a ring control?
Jim
LV 2020
(4,484 Views)
PropertyNode ?
(4,481 Views)
As nyc said, either of these properties will extract the strings from your ring
(4,462 Views)
Yes, you can read it that way, but not write.
Jim
LV 2020
(4,433 Views)
With rings you can write it that way, by property node, even at run-time.  Enums you can't write at run-time Rings and combo boxes you can.  Some minor points but well worth knowing.Smiley Wink
(4,427 Views)
As said previously...
(4,426 Views)
Sorry, I wrote this VI a long time ago. The label says ring but it is an enum.
Jim
LV 2020
(4,413 Views)
