exporting block diagram image
Hi Altenbach,
i have a similar problem.
could you please go through the link below?
http://forums.ni.com/t5/LabVIEW/Probelm-with-Printing-FP-image/m-p/2250888/highlight/true#M714331
thanks
RENN
Kudos always welcome for helpful posts 🙂
Message 11 of 14
(1,508 Views)
I know this is an old post, however if it can help someone I would like to help:
if you want to get the code in order to paste it in a document the easiest way is just go to block diagram, then Ctrl+A (or edit: select all) and then Ctrl+C. With this, go to your document and do Ctrl+V.
This works for me Smiley Wink
Message 12 of 14
(1,221 Views)
Snipping tool. The only screen capture tool you will ever need IMO. Everything else is too tedious.
PaulG.
Retired
Message 13 of 14
(1,214 Views)
great Alten Bach sir. I am really happy with your program.
Thank you so much.
Message 14 of 14
(1,133 Views)
