expressxy
I was just curious in looking at the expressxy subvi attached, it looks as if there is an array constants with an array inside? Am I misinterpretting this because I thought this could not be done.
(3,586 Views)
Accepted by GregFreeman
Ok figured it out. Thats an array of clusters. Each cluster is an array of doubles. To replicate create a numeric constant of Double precision. Put that into a array constant/container. Repeat. Take those 2 arrays of doubles and place them into a cluster constant/container. Now place that structure into a array constant/container sized up so it doesn't just lay on top.
Remeber: if you have the vi ctrl+H is your friend Smiley Wink
Message Edited by GovBob on 02-23-2009 05:57 PM
Now Using LabVIEW 2019SP1 and TestStand 2019
(3,566 Views)
ah, thanks for  clarifying! I was just a little confused looking at first glance.
(3,544 Views)
Sweet. Thanks for solving the question.
Just as an FYI, you can have an array of clusters, a cluster of arrays. You can't have arrays of arrays. The workaround to have an arrays of arrays is to have a cluster of arrays and drop that cluster into an array.
Warm regards,
Karunya R
Applications Engineer
(3,527 Views)
