extendable cluster of named images
I need to create a cluster containing named images programmatically. The number of elements in the cluster may vary. How can I edit the names of the images in the cluster? I tried something with references and property nodes but it doesn't work. Please, see the little example program in the attachment. Can anybody give a hint?
Peter
(2,465 Views)
Hello Peter,
unfortunately you forgot to attatch the example. That is why I dont know exactly what you are trying to do.
But just as a hint: Did you think about creating an array of a cluster? Build a cluster containing an image and its description and than create an array of it so you can programmatically vary the number of images and edit the descriptions.
Regards
Ingo Schumacher
Systems Engineering Manager CEERNational Instruments Germany
(2,453 Views)
Hi Ingo,
no, I didn't forget the attachment but somehow it has gone lost. I attach it a second time.
I already considered to use an array. However, an extendable cluster would be much smarter because I could use the "Unbundle by name" function at any location in the diagram where I need a particular image out of the cluster, and I didn't have to worry about picking the right element from the array.
Any idea how to name the cluster elements programmatically? It must be feasible using references but I couldn't figure out how to do it exactly until now.
Greetings from Ingelheim,
Peter
(2,437 Views)
