Home
Community
Discussion Forums
Most Active Software Boards
Topic
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
external code
external code
ASCologne
Member
09-07-2004
04:11 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
Hallo,
I a complex program I havo to improve I found a "link" to external code called "lm_fit.lsb". Does anybody know where I can find that code? A file with that name does not exist.
Arno
0
Kudos
Message
1
of 2
(2,534 Views)
Reply
Re: external code
Enrique
Active Participant
09-07-2004
07:30 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Arno;
The .lsb refer to a CIN node in one of your VIs. You need to contact the developer of that VI to give you the .lsb file.
Regards;
Enrique
www.vartortech.com
0
Kudos
Message
2
of 2
(2,534 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
