external code
Hallo,
I a complex program I havo to improve I found a "link" to external code called "lm_fit.lsb". Does anybody know where I can find that code? A file with that name does not exist.
Arno
(2,524 Views)
Arno;
The .lsb refer to a CIN node in one of your VIs. You need to contact the developer of that VI to give you the .lsb file.
Regards;
Enrique
www.vartortech.com
(2,524 Views)
