external trigger/clock source
Ben,
I do not need to read in a value, I simply need my loop to iterate in response to an external trigger (or clock signal...maybe I have my terms mixed up). We were actually thinking of using an NI PCI-6534 high speed digital I/O card.
Message 11 of 13
(796 Views)
Ok now we are getting somwhere!
Double check the spec on the board but,
You may be able to do what you want by using an extertnal clock to gate out the values you queue up to the buffer.
Check your board!
Ben
Message 12 of 13
(796 Views)
Yep, I think the NI-6534 will be able to handle this! Thanks for your help and patience Ben.
Cheers,
Lei
Message 13 of 13
(796 Views)
