extract plot names from waveform
Hello
Is it possible to extract plot names from an array of waveform to a new array that contains all the plot names.
(3,257 Views)
If you want extract the information from a frequency domain graph means, you will get a cluster of data with F0 representing starting frequency and delta f represents frequency resolution and 1D array of magnitudes.
(3,250 Views)
I think the data is in time domain format. I am able to get only one name by creating property node in waveform graph. Is it possible to get all of them at a time.
(3,246 Views)
what does mean by "all of them at a time"?
Please post your code, so that i would be esay for us to help you.
(3,237 Views)
Accepted by tmbejoy
If you are using Waveform data types to update your plot then you can iterate through all channels and pull out the name attribute or,
You can use a For loop that uses the iteraction terminal to drive the "Active Plot" property of the indicator and then pull the name using a second (preferably an expanded property node) and let the names pile up in an auto-indexing output tunnel.
Ben
(3,214 Views)
