extracting just the first value from a 2d string array with data from sql
Hi, i am selecting some data from mysql and putting them into a 2d string array. For my diploma project, i am trying to extract from that array just the first value because i am refreshing the array always ( deleting them at the end of the application, pressing a button and it's refreshed). I have tried everything, using a duplicate, using the reference of the table and it's not working.
here you can find some screenshots . could you guys help me because i m kind of blocked here and i need to present my project xD
just the first column is populated. i have no experience with labview, but i need to simulate something using labview and codesys, the connection been made using OPC. thanks guys
(4,501 Views)
Hi mihai,
Simple basic LabVIEW: to index an element from an array you should use the IndexArray function…
When you want/need to use LabVIEW you should learn the basics first: there is a "Training resources" section right in the header of the LabVIEW board. And NI also offers the online self-paced courses for free right now, so you could immediatly start with "LabVIEW Core 1" training!
(4,494 Views)
Hi, i have tried using the indexarray, but it's not working when it comes to the reference. after duplicating the array, it was working, but i need to use it as a reference so that it updates while running the app.
also, i have watched the tutorials
(4,491 Views)
Hi mihai,
Why do you need any references to "update it while running the app"?
(To update an indicator you just need to use a loop and write more than once to that indicator…)
Why do you need to "duplicate" an array indicator when you just need to use a wire?
Simple like that:
(4,486 Views)
hi, thanks a lot of the replies and the pieces of advice provided,
i need to use the reference because i am extracting data from my database ( SQL ) using select, and in my main program, I call the sql function everytime i press a button. Long story short, but i am trying to accomplish here is to simulate the returning of a book automatically using codesys and i need to extract a code ( ISBN CODE for the book) in order to update my sql using delete, insert update etc.
As you can see in the screenshot below, i dont know why, but it's not working, as you can see bellow
trying to replicate my array :
 that s what i have done before posting
trying to use the reference ;
(4,470 Views)
Accepted by topic author mihai_badea
Hi mihai,
I still don't see a use case for using references here.
You read data from SQL database: use the data you got and apply IndexArray on it!
As you already took some courses (did you?) you know the purpose of control references. A reference is like a pointer to a control, but it is NOT the value of that control!
LabVIEW comes with a huge example library, and there are examples explaining how to use references!
  • Basically you need to use a property to read the value of the control referenced by that reference.
  • Generally it is a bad idea to use references when a simple wire would work too…
(4,446 Views)
thank you very much, using the property worked perfectly for me, appreciate your efforts trying to help me 🙂 thank you again
(4,426 Views)
