fading out/in a graph
Is it possible with LabView to show a graph only if a certain button is pushed?
I'd like to make diagram with several measurement point, displayed as numbers for a given time. If one is ineterested in the time-dependency it should be possible to fade in the graph.
Is this possible with LabView?
Thanks for helping.
(3,272 Views)
Accepted by TobiasMeier
Create a visible property node for the graph. It uses a simple boolean input, true, graph is visible, false, graph is not visible.
- there is always an easy way, but it is always the hardest to find
(3,267 Views)
I'm not sure if you want to gradually fade in the visablility of the whole graph or want the traces to fade out like they did on old Storage Scopes.
If it is the latter see the attached that used to work in LV 7.1.
Ben
Message Edited by Ben on 03-20-2009 07:45 AM
(3,263 Views)
