failed to save for autorecovery
Good Morning Jeff,
Do you think you could send me an email to le tme know where to send the code? We have in NDA in place with NI, so you can check it out to your heart's content, but I can't post it to the forum. 🙂
Tim
Data Science Automation
CTA, CLA, CLED
SHAZAM!
Message 11 of 23
(3,015 Views)
Sorry for the delay in response.  I would recommend zipping up your project and uploading it to ftp.ni.com/incoming.  Only people internally at NI have access to download from that location.  Hope that works for you, please let me know what the filename is once you've uploaded it, thanks!
Message 12 of 23
(2,993 Views)
Jeff,
Look for "SourceCode-2008_0702c-TDN.zip", the project is ExplosionPropogation.lvproj. You should see the copy in there as well.
-Tim
CTA, CLA, CLED
SHAZAM!
Message 13 of 23
(2,981 Views)
This happens to me too. Just once a session when I run a vi from the project.
Both on projects created with earlier versions and ones created with 8.5.1.
Running CRIO so FPGA and RT.
I'm not particularly worried about it, but would be good to  find out why.
Lucy
Message 14 of 23
(2,933 Views)
Accepted by Mellobuck
This is a somewhat annoying but generally harmless bug associated with LabVIEW attempting to autosave certain projects containing variables.  This was reported to R&D (# 115766) for further investigation.
Message 15 of 23
(2,908 Views)
Thanks Jeff! That's a 5-star answer if I ever heard one.
Geez, I didn't even end up using that shared variable library...it's an artifact from previous versions of some of the VIs
CTA, CLA, CLED
SHAZAM!
Message 16 of 23
(2,898 Views)
Thanks for the info and follow-up Jeff
SteveA
CLD
FPGA/RT/PDA/TP/DSC
Message 17 of 23
(2,893 Views)
This error is occurring with me also. I have a project file that worked OK in LV 8.5 but faults in 8.6.
I tried the copying with a new name fix but this did not work.  Annoying.
cheers
Frank Greenslade
Christchurch
New Zealand
Message 18 of 23
(2,671 Views)
Hi, Frank,
Try to open .lvproj file in any text editor and look for "variables" or something like that (don't remember exact entries for that). Delete it if present (save backup copy of your .lvproj file before).
Or post your lvproj file here if it possible.
Andrey.
Message 19 of 23
(2,666 Views)
FRG - please post your project file here if possible (preferably saved in 8.5 still).  I think only the LVPROJ file would be necessary.  I believed this issue to only be in 8.5.1 and resolved in 8.6, but if you're seeing this in 8.6 as well, I'd like to take a closer look.
Message 20 of 23
(2,626 Views)
