fan control through PWM using digital output of sbRIO
Hi all.
I am a new user of LabVIEW, so excuse if the question sounds basic.
I want to control two 4 wire fans (required for ventilation purposes) using PWM outputs. I am using sbRIO 9627 and would like to control digital RIO Mazzine ports (DI01, DI02...) to control the fans. I would like to know what could be the easiest logic in terms of LabVIEW VI that can control the fans rpm.
(2,224 Views)
Hi Satoo,
Sorry you've been waiting a while to hear back. I am assuming that you have managed to have this fixed by now, but if not, you can see some example code here:
https://forums.ni.com/t5/Example-Programs/Generate-a-PWM-Pulse-width-modulation-Output-Signal-On-cRI...
There's also this white paper that briefly describes PWM: https://forums.ni.com/t5/Example-Code/Pulse-Width-Modulation-PWM-IP-Core-for-LabVIEW-FPGA/ta-p/39961...
Nick
(2,131 Views)
