Not able to use snippet in my LabVIEW Environment
While i am trying to drag and drop code snippet to my LabVIEW BD only the link gets copied in my BD and the same happens in my FP too.
Not able to get information from the below post.
http://forums.ni.com/t5/LabVIEW/snippet-to-code-gt-don-t-work-if-LV-started-as-admin/m-p/2042848#M66...
Do i need to change any settings in my System?
Palanivel Thiruvenkadam | பழனிவேல் திருவெங்கடம்
LabVIEW™ Champion |Certified LabVIEW™ Architect |Certified TestStand Developer
Kidlin's Law -If you can write the problem down clearly then the matter is half solved.
Message 1 of 17
(4,937 Views)
I faced this issue also. Sometimes saved the snippet to local and then drag and drop of snippet works.
uday
Message 2 of 17
(4,934 Views)
I tried saving the snippet as my local copy, that too is not helping me
Message 3 of 17
(4,923 Views)
Hmm, strange this should work. So first save the snippet for example into your Documents folder, and then open the folder. After this a drag&drop operation should work.
And I agree it is annoying that a drag&drop does not work from browser into a BD. As much as annoying as I cannot attach a VI to a forum post using Firefox. Always need to open Chrome or IE only for this operation, very dumb 😄
Message 4 of 17
(4,914 Views)
Hi Blokk,
see this thread on problems uploading different file types to the forum.
After more than 2 years of complaints I got a solution with help from Lili…
Message 5 of 17
(4,909 Views)
Thanks the second option works for me now, just restarted my LabVIEW Application.
How to make it work the image snippet from my browser \?
Message 6 of 17
(4,906 Views)
Also interested if someone knows a way... 🙂
Message 7 of 17
(4,903 Views)
Please provide full information:
  • LabVIEW version
  • Browser version
  • OS version
Message 8 of 17
(4,890 Views)
@GerdW wrote:
Hi Blokk,
 THANKS! 🙂 I just had to reset the second preference (the 1st was not present), and I am able to post VI! 😄  From here: http://forums.ni.com/t5/Feedback-on-NI-Discussion-Forums/Problems-uploading-a-ZIP-file/m-p/3241156/h...
Sorry PalanivelT for hijacking! 🙂
Message 9 of 17
(4,888 Views)
  • LabVIEW version
  • Browser version
  • OS version
I also cannot drag&drop from Firefox into BD, so I also provide versions here:
LabVIEW 2015 SP1 32bits & 2016 32bits
Firefox 48.0.2
Windows 7 Enterprise SP1 x64
Message 10 of 17
(4,882 Views)
