Not able to use snippet in my LabVIEW Environment
Hi Blokk,
drag&drop from FF never worked (and I think will never do): save the snippet to your desktop/download folder and drag it from there into LabVIEW BD window…
Message 11 of 17
(1,567 Views)
@GerdW wrote:
Hi Blokk,
I cannot believe, but I just tried to drag & drop from my Firefox into my DB (LV 2015 SP1 32bit), and it worked!!! 🙂 I have no idea why it works, since as I remember back, this never worked for me...but I did not try it for a long time, because I thought it just does not work 🙂
Tested with my above version Firefox, and using this snippet: http://forums.ni.com/t5/LabVIEW/Simulation-is-not-running/m-p/3343124/highlight/true#M981978
Edit: I will test it later with another PC, as I remember there all I got was the blue link of the png file, and not the VI itself after drag & drop...
Edit2: drag & drop also works with LV2016 and testing on this snippet: http://forums.ni.com/t5/LabVIEW/LabVIEW-Feature-Report-quot-Find-text-quot-fails-to-identify/m-p/333...
edit3: now we should try to figure out, what is the difference between systems with working drag & drop, and non working behaviour... the only change I did recently was the one proposed by GerdW, but it was for the VI attachment, not for drag&drop...is there any relation? Could you test it?
Message 12 of 17
(1,564 Views)
Just tested drag & drop from Firefox into BD using another laptop, and it works here too.
Versions:
LabVIEW 2015 SP1 32 bit
Windows 7 Pro SP1 32 bit
Firefox 48.0.2
edit: maybe a recent Firefox update fixed this issue? PalanivelT, could you provide your version numbers as I did?
Message 13 of 17
(1,554 Views)
Even for me it worked long before! but its not working now (*No system chnages made in between)
LabVIEW : 15.0 (32bit)
Windows 7 Enterprise
Firefox 48.0.2
Palanivel Thiruvenkadam | பழனிவேல் திருவெங்கடம்
LabVIEW™ Champion |Certified LabVIEW™ Architect |Certified TestStand Developer
Kidlin's Law -If you can write the problem down clearly then the matter is half solved.
Message 14 of 17
(1,547 Views)
First you should check whether you can drag&drop pre-saved snippets from Windows Explorer (i mean where you can see your files, not IE). If this does not work either, you could try to re-install the LAVA Code Capture Tool in VIPM. If this part works for you, try to reset Firefox to see if it helps?
Message 15 of 17
(1,539 Views)
Presaved snippets works fine for me!
Message 16 of 17
(1,535 Views)
I had an issue where snippets were not able to be dragged into the block diagram.  Instead only an icon appeared indicating that the drag and drop feature was not possible.  I found that if LabVIEW is run as administrator the drag and drop feature is disabled.  Once I launched LabVIEW without administrator privileges the drag and drop feature was enabled allowing me to use the snippets.
Message 17 of 17
(898 Views)
