fase color in menu bar of LV7 installed on Windows 2000 machine
When I install LV7 on a compaq EVO machine running windows 2000 the color of the menu bar on the Labview windows is black. Other windows with the same problem: 1) "controls" window in LV7 (and probably all other popups) 2)windows of executables.
All other applications look normal except LV7.
If I upgrade to windows XP the problem disappears.
Any ideas?
Scientia est potentia!
(2,658 Views)
The most likely culprit is outdated video drivers on the Win2K system.
Make sure you have the latest drivers from the card manufacturer and also make sure you follow the uninstall/install procedure. Some drivers cannot be simply upgraded by installing the new version. You must first completely unsinstall the old drivers first.
Ed
Ed Dickens - Certified LabVIEW Architect - DISTek Integration, Inc. - NI Certified Alliance Partner
Using the Abort button to stop your VI is like using a tree to stop your car. It works, but there may be consequences.
(2,658 Views)
I have seen this problem once before. Could you provide more details about your video driver? What service pack is your Windows 2000 machine?
Feroz
(2,658 Views)
Updating the video driver had worked.
Thank you.
(2,658 Views)
First it seemed we had fixed the problem.
But when the administrator logged out and I logged back in, wer had the same false color problem.
At this point, we had decided that instead of hunting down service pack etc... we will just upgrade to Windows XP.
That should certainly take care of our "colorful" problem. 🙂
(2,658 Views)
I too am seeing this problem. I have an ATI 3d Rage Pro card. The defualt driver comes with 2k. Are there any solutions to this problem?
(2,658 Views)
