fatal error code 1097
When I run a vi with a call library function I get error code 1097.
The strange thing is that I only get this error when I run the vi as a sub vi in another main vi.
If I run the vi standalone I don't get the error.
(4,177 Views)
Hi bart,
just a little bit more informations for us?
What kind of library? Maybe attaching the vi? Some (default) parameters not wired when running as subvi?
(4,168 Views)
I am sorry,
I thought I attached the vi.
(4,161 Views)
Hi Bart,
I couldn't find a problem in here. Maybe it's the dll as suggested by the error message...
Except for your (missing) subvis: Do they do the conversion correctly?
One general hint:
you can wire the error cluster directly to the case structure selector or while loop stop condition!
(4,155 Views)
