requirements gateway excel
I have a problem to connect my testspecification in excel to the requirements in word, i tried to add an column with [Covers: xxx] and when testing the expression i get all column but not connected to req.spec
1. How to get only the text in column x
2. How to connect the [Covers:xxxx]
Could it be that I convert the word template to use Header2, Header 3 as requirement, because not to change the original req doc.
Example in word
1.10 Download software
 type expression requirement: ^Heading 2\t(?:([\d\.]+)[ \t](.+))$
Excel:
|1                         |2                                           |3                             |4                                     .......
[Covers:1.10]      1.10 Download software      Test with.....             070927/pv0.23               ........
Type expression covers reference: \|1 (\[Covers.+)
The excel should cover Excel.
Best regards CB
Message 1 of 1
(2,496 Views)
