file error message from LV 3.1.1
For the older users:  I'm using LV 3.1.1 and getting a file read error -43 from the "open, read abc, close" VI.  I can't find this in any of my manuals.  Can anyone help?
Thanks!
(2,790 Views)
LV 3.1.1?  You're using Windows 3.1?  Time to upgrade.
Bill
CLD
(Mid-Level minion.)
(2,716 Views)
Hi! Reflector,
I highly encourage you to upgrade your LabVIEW to a more recent version. That way it will be much easier to find help, KB articles, tutorials, etc.
I tried to use my version of LabVIEW's help and error explanations. This is what Error -43 explanation says:
"Error -43 occurred at an unidentified location
This error code is undefined. Undefined errors might occur for a number of reasons. For example, no one has provided a description for the code, or you might have wired a number that is not an error code to the error code input.
Additionally, undefined error codes might occur because the error relates to a third-party object, such as the operating system or ActiveX. For these third-party errors, you might be able to obtain a description of the error by searching the Web for the error code (-43) or for its hexadecimal representation (0xFFFFFFD5)."
Now... I am not 100% sure if Labview has the same error codes for LV3.1.1 and LV2017, which is the version I have.
Also, I could not find the *.vi you make reference ("open, read abc, close" vi). But I found this article for error 43 on an Open/Create/Replace File VI  <http://digital.ni.com/public.nsf/allkb/E78D4D60B08E4CCE86257297005BB706>
I hope this information is useful!
(2,695 Views)
