file not found message during load
I am trying to ascertain what resource my built EXE can not find during startup. While the reource IS ultimately found, and the APP runs, it displays the "VI not found" dialog during load.
Any good way to either silence this dialog box of ascertain programmatically which VI is in the wrong location?
(2,777 Views)
If you do have VI which is to be loaded dynamically...
This VI might be of helpful in one way or another in the VI's calling path.
Hope I got your problem right.
Cheers!
Ian F
Since LabVIEW 5.1... 7.1.1... 2009, 2010, 2014
依恩与LabVIEW
LVVILIB.blogspot.com
(2,777 Views)
If you add c:\ to your VI search path in LabVIEW it generally REALLY slows down the search for obvious reasons. Then while it is searching every file you have, the dialog will stay up for a while and you can see exactly which VI LabVIEW is searching for.
(2,777 Views)
