file output
Hi guys,
    I want to save my output into multiple files ( one file for each scan), but right now my program save all the scans into one file. how to fix it? Thanks so much!
    Lei
Message 1 of 11
(4,619 Views)
Just put a for-loop around your Write to Measurement File Express VI and configure the Write to Measurement File Express VI to save to a series of files (double-click on it the VI).
Message 2 of 11
(4,607 Views)
Thanks, I actually tried to configure it but every time it saves a lot of files even I only scan three times.
why do you suggest the for loop? I am using the for loop to control the number of scans in my program, but why do I need a for loop around the "write to measurement" vi?
Message 3 of 11
(4,601 Views)
Did you not say you wanted each scan in a separate file? The DAQmx Read returns all your scans, so if you want to save them into separate files you need to peel them off and save them individually.
Message 4 of 11
(4,583 Views)
Thanks. I tried but it didn't seem to work.
Message 5 of 11
(4,569 Views)
So why didn't you attach this code with the for loop that does not seem to work?
Message 6 of 11
(4,552 Views)
Message 7 of 11
(4,534 Views)
I had told you to place the loop around the Write to Measurement File, not around the whole code. I can't really follow your code because it's so sloppily wired, and all the subVIs are missing. It appears that this is a different program than what you had before. In the previous one you had a DAQmx Read returning the data. I see no DAQmx functions in this new VI.
Message 8 of 11
(4,513 Views)
Thanks a lot smercurio,
first of all, I have to put the loop around the whole code in order to repeat the scan.
sencond, the code is the same. I never use DAQ, all the sub VIs are from Princeton instruments to control our CCD camera.
Message 9 of 11
(4,502 Views)
No, it's not. Look at the original VI you posted. Now look at the second VI you posted.
Message 10 of 11
(4,495 Views)
