fill values for a ring control in a cluster
Hi
I would like to crate a list of values for a rind control at the beginning of my program.
The problem is the ring control is in a cluster.
I do not know how to access the properties of the ring.
I found this while searching in the forum:
http://forums.ni.com/ni/board/message?board.id=170&message.id=131409&a#M131409
" Place a "To More Specific Class" after Index Array, create a constant for "target class" and select GObject>>Control>>Cluster>>Cluster. Now the wire will know that it points at a cluster and give you access to the cluster properties."
But I do not know what GObject is a ring control?
Amose
Message Edited by amose on 09-07-2006 05:30 AM
(2,734 Views)
How about this?
Of course, you could also just click on the ring inside the cluster and create a property node linked directly to it.
___________________
Try to take over the world!
(2,726 Views)
