find VI version
How do I find out which version a VI was developed in?
(4,255 Views)
That shouldn't be too hard to find.
*looks*
...Wow, I have no idea. >_<
(4,232 Views)
There's an application method for this:
Ton
Message Edited by TonP on 12-05-2007 08:47 PM
My LabVIEW Ideas
(4,230 Views)
can you please tell me how to find this method?
(4,216 Views)
Right-click on the block diagram, navigate to the "Application Control" palette, and select the "Invoke Node" item. By default the class selected is the Application class. All you need to do is left-click on the "Method" box and that will pop up a long menu. Select the "Get VI Version" menu item, and wire in a path to the VI.
(4,182 Views)
That works like a charm. Thankyou very much for your help.
(4,161 Views)
