how to use a queue with dynamic data
When using a collector I have found that it significantly slows down my loop times. I am using LabView7.1 on a Dell PC with Windows XP.  If I use a queue with dynamic data do you think that will require less of my processor and allow for faster loop speeds?
I have created a queue using dynamic data in one loop and I want to retrieve all available samples each iteration in a slower loop. If I use the flush queue I get a 1d array of dynamic data. What is the best way to convert the 1d array of dynamic data so that the array of dynamic data is consolidated back into a single dynamic data type? Any help would be much appreciated.
(3,816 Views)
Hi Dennis,
You could for instance wire the array to an auto-indexed for loop. I attach an example. I assume you wish to concatenate the arrays a singel waveform.
Hope it helps,
Pelle S
Account Manager
National Instruments Sweden
(3,798 Views)
