find difference of values and slopes for a specified interval in X coordinates
Hi all,
Suppose i have a sine wave of 100hz freq with sampling freq of 1000hz. I want to plot two points on a X-axis and i want to find difference of corresponding y values and display it in the front panel. How do i go about finding the slope for the same. Any help would be appreciated.
KM
(2,525 Views)
What do you mean plotting two points? You have the linear fit vi using that you can find the slope.
(2,507 Views)
If you have the plot I will assume that you have arrays of X and Y values. For each of the X values:
1. Use the Threshold 1D Array function with the array of X values as the array input and your target X value as the scalar input. The output is a fractional index of where that X value falls in the array of X values.
2. Use the Interpolate 1D Array function with the array of Y values as the array input and the fractional index from the threshold operation as the index input. The result is the interpolated Y value at the specified fractional index.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(2,493 Views)
