1K XMODEM File tranfer VI
Hi
Does anyone have an example VI for file transfer using 1K XMODEM protocol
Michelle
Message 1 of 14
(8,205 Views)
You will probably need a third party tool to get this functionality in LabVIEW: http://digital.ni.com/public.nsf/allkb/765DB82497081D41862565370063E3A0?OpenDocument
Message 2 of 14
(8,187 Views)
Hi Rob
I have an XMODEM example VI, I guess I am going to have to rework it, only I did not want to reinvent the wheel if someone out there had a 1K XMODEM VI for file transfer already.
Thanks for the info thoe.
Michelle
Message 3 of 14
(8,182 Views)
Hi Michelle,
How did you solve this in the end? I found Xmodem_VISA.zip on
http://forums.openg.org/index.php?showtopic=258&hl=xmodem
But that needs to be rewritten for 1K Xmodem as well. And same like you: not that I can't, but if it has already been done...?
Best regards, Matthijs
Message 4 of 14
(8,006 Views)
Hi Guys
Original example reworked so enquirey now close
Michelle
Message 5 of 14
(7,986 Views)
Hi Michelle,
I am sorry but I don't understand your message. Is there a working 1K Xmodem example somewhere now?
Ifso, where?
thanks, Matthijs
Message 6 of 14
(7,975 Views)
excuse me I have LabVIEW 2011 and this exemple is made on labview 2012 and I can't open it 😞
I wonder if you can help me finding a solution for my problem 🙂
Message 7 of 14
(7,341 Views)
Any one has a XMODEM 1K file Transfer vi, if u have any idea on XMODEM 1K file Transfer please post the replay.
In my Project i want to transfer a 1K XMODEM file transfer through Serial Port.
Message 8 of 14
(7,111 Views)
Attached Xmodem VISA.zip is working under Labview 2010 (and probably higher).
You can use "Xmodem Send - VISA.vi" inside this library to send files.
Message 9 of 14
(7,101 Views)
In that library for 1K XMODEM file send 1K option was not there, that option is in Receiving XMODEM, but we need 1K option in send XMODEM.vi.
Message 10 of 14
(7,086 Views)
