NI 9206 Delta sigma or SAR module?
I am planning to use the cRIO Waveform library for NI cRIO 9074. I am having NI 9206 C-Series Analog input module.
The question i have is whether should i use the Delta-Sigma application example or the SAR acquisition mode example.
Basically i want to know whether the NI 9206 is a delta sigma module or a SAR module.
Appreciate your help.
(2,982 Views)
Accepted by topic author swami86
HI Swami,
9206 is a SAR module, in general Delta-Sigma tend to be 24 bit and they have very fixed sampling frequencies which they can run at, if you can set any sample rate in a range then it is SAR.
Cheers,
James
James Mc
Ask me about Rust & NI Hardware
My writings are at https://www.wiresmithtech.com/devs/
(2,960 Views)
Thanks a lot James for your quick reply.
(2,955 Views)
