find error and it's index where it occured?
I have attached document and Vi file to explain problem. Please look in to it. thank you.
Message Edited by Amy222000 on 04-06-2005 02:40 PM
Message Edited by Amy222000 on 04-06-2005 02:41 PM
Message Edited by Amy222000 on 04-06-2005 02:43 PM
Message 1 of 9
(3,594 Views)
Try this example and see if it is what you are looking for.
Message 2 of 9
(3,567 Views)
Thank's it was exactly what I ment!!
Message 3 of 9
(3,538 Views)
Please look attached files for question and modified VI. Thank you.
Message Edited by Amy222000 on 04-28-2005 04:46 PM
Message 4 of 9
(3,518 Views)
I can not execute the program because a sub vi is missing (read 2d string from excel).
Message 5 of 9
(3,493 Views)
I have also posted question regarding getting errors only at the end once instead of in between. I have sent modified VI for error handling after this post. Please look in to that also if you get a chance. It is under subject-" How can I find error once..." Thank you.
Message Edited by Amy222000 on 04-29-2005 12:27 PM
Message 6 of 9
(3,488 Views)
Still can not execute. The sub vi you attached also contains sub vi's that are missing. You might try attaching the program as a llb.
Is it the array of error that you want to change colors(flash) or is it the pop up error message you want to flash?
Message 7 of 9
(3,475 Views)
sorry the subject is " I want error message atlast only once".
Message 8 of 9
(3,475 Views)
I did not have the complete program so I could not test the Excel part.
See if this is even close to what you are trying to do.
I had to remove the read 2d excel because I did not have the needed sub vis.
Message 9 of 9
(3,466 Views)
