find phase of channel from reference channel
Okay, Lets say I have two active channels that I am using from my DAQ board. They are both 60hz signals. I call one my reference channel and from it I want to determine the phase of the other channel based on the reference. I imagine I could figure this out using background knowledge, but is there a quick and easy way todo this in LabVIEW?
(2,629 Views)
You can for example use the Extract Single Tone Information.vi located in your Analyze>>Waveform Measurements palette. Run the VI on both your signals and subtract the two phase results from each others.
(2,629 Views)
Sure! Try the attached vi.
eric
Eric P. Nichols
P.O. Box 56235
North Pole, AK 99705
(2,629 Views)
