find the average of each 500 values in a column [text file]
please help, i hv a text file with three columns of integer values. I need to take 500 values in each column and replace them with their average.
Message 1 of 8
(2,834 Views)
All your posts are the same thing.  You provide a file and a task and then say "Please help" but you never actually show that you've at least tried to do your own work.
Post your attempt at this task an you'll get better assistance...
LabVIEW Pro Dev & Measurement Studio Pro (VS Pro) 2019
Message 2 of 8
(2,823 Views)
i did it
Message 3 of 8
(2,821 Views)
Congratulations! Smiley Happy  I'm still stuck with LabVIEW 2010 so I can't open your code.  Have you tested it?
Message 4 of 8
(2,814 Views)
Accepted by topic author Mahisnair
A lof if this could probably be simplified. Here are some ideas.... Many thing could be improved even more.
Message 5 of 8
(2,791 Views)
@Niquist: i have only labview 2011 to use friend, the code is working.
Thanks for the reply
Message 6 of 8
(2,771 Views)
Message 7 of 8
(2,770 Views)
Message 8 of 8
(2,764 Views)
