i interfaced labview with gsm using visa serial if i write AT as input i should get OK as output but i am getting AT OK AT OK AT OK repeatedly eat i shld do
(2,225 Views)
Use the run button and not the run continuously button?
Its very difficult to guess without seeing the code that is causing your confusion.
(2,213 Views)
