find time shift between two signal from measurement file to find velocity
Ha khalid,
set the values shown in your CHART to default and save the VI. Then attach the VI…
Message 11 of 15
(1,223 Views)
Hi GerdW
i have save data in graph as default data
thanks a lot
regards
khalid
Message 12 of 15
(1,220 Views)
Hi khalid,
that's what I expected before:
- Your signals seems to be very noise.
- When zooming in you see some "spikes" on both signals - at exactly the same samples/time…
So I would conclude: there is no delay…
Again I repeat my question: What is the EXPECTED delay between both signals?
This is what I had in mind when I made the suggestion to crosscorrelate two signals:
(I faked the signal using a function from signal generation palette.)
Message 13 of 15
(1,217 Views)
the two lasers are 2 mm apart , so i assume that there has to be time delay between the signals ,so from the peak of Rxy function i can get the delay between the two signals
Message 14 of 15
(1,212 Views)
I know nothing about your used measuring principle, but what I see from the zoomed-in-graph Gerd posted (first graph in post 13) you have a sample rate of 100 kHz (five datapoints between major ticks). This is a cycle time of 10^-5 s.
The delay for a light signal with a velocity of aprox. 3*10^6 m/s is for a distance of 0,002m around 6,67 * 10^-10 s. This is far away from your sampling time.
Could this be the reason, that there is no delay to see?
Greets, Dave
Message 15 of 15
(1,208 Views)
