finding pattern using image processing
today only i am going to work with that i will tell the feed back tomorrow because the system i am using now doesn't have LabVIEW
Message 11 of 14
(1,721 Views)
i gone through your program its nice and solves my problem some how but in my image i am going to capture may contain more than one dot is any other method you have so that we can take the region of interest for the exact dot we focus. please post the attachement if you can.....m thank you very much for the post you made.....
Regards
P.Anand,
Madurai Kamaraj University
Message 12 of 14
(1,704 Views)
Which program did you follow?
Message 13 of 14
(1,700 Views)
Whenever you were talking about my program and images, thank you !
(dont forget the kudos on the right Smiley Happy )
When you have multiple dots where only one counts, or little disturbances, you have to filter the picture first.
Nobody can do that for you, because you have to see what/where/how/... on real images.
When multiple dots have to be detected, with both their results, onother algoritm is needed.
Also filtering is necessary here: What if they are too close or on top of eatchother, what if only one,...?
I hope it helped to give you a jumpstart.
Steven
Message 14 of 14
(1,694 Views)
