first acquisition very slow
using 2 loops and cFP as target,, one for analog acqusitions and one for digital acquisition, the first execution of each loop is very slow ( in seconds!)  for each read operations.
After that first loop, the acquisitions are fast.
I have five loops and all the others loops start normally.
Is it bad to read each input seperalty ?.
Thank you
(2,336 Views)
I will give it a shot since no one replied today.  It is generally better to read the IO in a lock instead of one by one.  This condition is known as IO bound because the performance is being limited by the IO.  Assume you have 16 channels but you only need 6 of them.  It would usually be faster to read the 16 channels as a block and index out the data you need than making 6 separate reads.  I don't use cFP so speaking in general terms.
Matt
Matthew Fitzsimons
Certified LabVIEW Architect
LabVIEW 6.1 ... 2013, LVOOP, GOOP, TestStand, DAQ, and Vison
(2,319 Views)
