fix labview error
How to fix labVIEW error
I can't open example from labVIEW help
it is shown in attached file.
Message 1 of 9
(9,199 Views)
Hi ductuan,
while that error is nasty you can always open the VI in the path given in the help. You can also use the example finder...
(Maybe there is a problem with your LabVIEW installation preventing opening the example VIs with a click of the button in the help.)
Message 2 of 9
(9,176 Views)
yes it is true that it prevents opening the example VIs with a click of the button in the help
I can not find effective sullotion
Message 3 of 9
(9,171 Views)
I suspect you have a bad LabVIEW installation.  I recall seeing something similar on one of my systems, and discovered that a LabVIEW Service (the NI Service Locator) had "disappeared" (for reasons neither I nor NI Support could discern).  The "fix" was to totally remove LabVIEW and do a complete reinstallation.
What version of LabVIEW are you running?  I'm going to guess that it was LabVIEW 2017 or 2018, or you might have recently applied a LabVIEW Update ...
Message 4 of 9
(9,148 Views)
it is LabVIEW 2017.
This happened on some computers in my lab, so that I think that it may be the result of updating window 10 (window 10 version 1803).
I have already removed labVIEW and reinstalled it again. However, it still did not work.
Could you give me other solutions
Message 5 of 9
(9,146 Views)
There is a problem with a recent Windows update.  If you uninstall it, it will work.  (Trick is keeping it uninstalled if you are in a corporate environment.)
https://forums.ni.com/t5/LabVIEW/Script-Error-when-click-on-Find-Example-in-LabVIEW-Help/m-p/3857530...
See if your Windows update history has an entry for KB4462918 or 4462919
Message 6 of 9
(9,142 Views)
It means that I have to reinstall KB4462918 or 4462919 in window update
I will try it tomorow when I am at lab
Thank for your help
Message 7 of 9
(9,136 Views)
Accepted by ductuan.mta
It means you have to UNinstall those updates.
Message 8 of 9
(9,134 Views)
Now, all my computers run smoothly
Message 9 of 9
(9,105 Views)
