fixed point math with shift register on FPGA
This would be easy, but it's on FPGA.
I would essentially like to do what is shown, but with Fixed Point data. I also need my output from the add function to be <+,32,0> because it is going into a sine wave generation VI as the frequency. Basically I just want the frequency to slowly increase by "step size" at some predefined rate. Is it possible to do this? There must be some way I can do number to boolean array then boolean array to number, do some bitwise manipulation and convert back to the fixed point type I want. But, I can't figure it out. I have also read some of the fixed point articles on NI.com but with no luck getting it to work. Frankly, fixed-point math still eludes me.
Any suggestions?
(4,832 Views)
Accepted by GregFreeman
Ah, what the method of trial and error will do for you.
This seems to work.
(4,826 Views)
You can also configure the output of the Add function by right-clicking and specifying the output type.  LabVIEW automatically changes the output to a double to account for overflow of the fixed-point value, but you can override this and you will see a blue dot at the output to notify you that the output configuration has been coerced, similar to the red input coercion dot.
Donovan
(4,817 Views)
That sure is cleaner!
(4,815 Views)
