fixing the color of a color box
Hey all,
I am using a color box and i want to fix the color of the color box to a particular color even if i click on it. Is there a way of locking the color of the color box some how?
(2,937 Views)
hi,
Fix the colour that you want. Go to properties and disable it.It will be Locked while running.
Best of luck
Gaurav k
CLD Certified !!!!!
Do not forget to Mark solution and to give Kudo if problem is solved.
(2,935 Views)
Accepted by GEEK777
Thanks a lot!!!!!!!!!!!!!!!!
(2,928 Views)
Then please mark Gak's reply as the solution rather than your own thank you message.  If you go to the Options menu to the upper right of your message first, you will be able to unmark it as the solution.
(2,918 Views)
