float to bytes conversion using labview
in university project i want to transmit  float number serialy using labview. i dont know how to convert float into its individual bytes actualy i want to encode float in to its bytes. kindly help me about that
Message 1 of 20
(7,715 Views)
Use the type cast function and wire an array of u8 to the type specifier. That should work for you. You will get 8 u8's in the array.
Message 2 of 20
(7,694 Views)
i m a new user of labview kindly can u give me a block diagram of it. for example l want to convert 18.25 to its 4 bytes and then want to send it serialy in labview how can i do that? i shal be very thankful to u sir for this help
Message 3 of 20
(7,682 Views)
Accepted by ranazeeshanali
Sending "bytes" is typically done in the form of strings. SImply use typecast with the type input disconnected (or use "flatten to string").
To get started, easiest would be to use the example finder in LabVIEW and look for serial communications.
Message 4 of 20
(7,648 Views)
thnx  sir can u give me the block diagram plz
Message 5 of 20
(7,638 Views)
Just use the search button on the function palette.
Message 6 of 20
(7,631 Views)
help...find examples...search for "serial".
Message 7 of 20
(7,626 Views)
how to recover float number from its bytes then?
Message 8 of 20
(7,617 Views)
So you want to be spoon fed? Maybe try a function like type cast!
Message 9 of 20
(7,610 Views)
Why don't you do everyone a favor and try to put something together and show us what you got?  If you skate now, we all pay later.
Bill
CLD
(Mid-Level minion.)
Message 10 of 20
(7,589 Views)
