floating controls not changing at run time
I have some floating controls on my front panel because they are situated over a cluster. When I switch from edit mode to run mode or run to edit, my controls won't go from floating to not floating, or vice versa, until I either mouse over them, move a window over my LabVIEW window, or scroll on my LabVIEW window. I have tried restarting LabVIEW but it has not solved it. Has anyone else seen this and been able to remedie it? It's like my LabVIEW window is not refreshing until some event on it happens. Image below is before and after I scroll
(3,085 Views)
Interesting.  Obviously you need to force a redraw to work around this cosmetic glitch.  Try involking the method "Reinitialize all to default" on the  FP at launch.
(3,067 Views)
This is frustrating, and you may find that System buttons act differently than Modern, etc.
Group the "floaters" with your cluster, and you should be ok. It's a good practive anyway for when you move stuff.
Richard
(3,064 Views)
I had done that, but the problem is I have to use a local variable (Smiley Surprised queued state machine with no parallel loops...it's OK!!!) because I need to initialize the controls values at startup. So, if I put the buttons in the cluster, I then cannot use the latch mechanism. I guess I can try with a property node's value property. Will that allow me to still use latch?
(3,055 Views)
Double you, tee, eff (how's that for avoiding abreviations Smiley Wink). If I move the multicolumn LB so it's not floating, then everything resets properly the first time. Then if I run again, it goes back to the old behavior. So then I move it back so it is floating, the first time it works properly. The next time, it doesn't....weird.
It seems to all be triggered off the MC Listbox switching from either floating to not floating
(3,052 Views)
Accepted by GregFreeman
imstuck,
I didn't mean put the buttons in the cluster, I meant use the grouping tool to physically group the hovering buttons with the cluster. try it! Smiley Happy
Richard
(3,047 Views)
NICE!
(3,034 Views)
