folder
@gmazza wrote:
ehmmm???
Go to the File IO->Advanced File Functions palette.  There is a Get File Extension.vi in there.  One of the outputs is the file name without the extension.
Message 11 of 19
(1,747 Views)
I can not solve.
I repeat the problem: I have an array with an indefinite number of items. I want to eliminate the final part of each element.
Is there a way to do this?
Message 12 of 19
(1,724 Views)
Hi gmazza,
yes, there is!
FOR each element in array
  strip "final part of element"
NEXT
 Use an autoindexing FOR loop to iterate over all elements of your array...
Message 13 of 19
(1,721 Views)
Sorry. I still do not understand how to do ...
Ok, I have to use a for loop. But I can not delete a portion of each array element.
Message 14 of 19
(1,712 Views)
Hi gmazza,
it seems pretty straight-forward to me:
Replace the StringSubset function with any code you like to use for "stripping part of string"...
Message 15 of 19
(1,706 Views)
Or if you want to use an available function, which strips the extension.
Strip extension
I am not allergic to Kudos, in fact I love Kudos.
 Make your LabVIEW experience more CONVENIENT.
Message 16 of 19
(1,701 Views)
Message 17 of 19
(1,700 Views)
the problem is just to find a code to stripping the string...
Message 18 of 19
(1,691 Views)
Ok. Perfect. Frabto's solution works well and is very simple .. thank you
Message 19 of 19
(1,689 Views)
