forループ 小数
このforループに0,0.01,0.02,0.03…4の値をそれぞれtに代入してほしいのですがforループはやはり整数しか扱えないのでしょうか
tに代入するだけなら
このようにできるのですが波形を表示させる際に
横軸がforループで用いた0から400になってしまうのですが横軸を0,0.01,0.02,0.03…4にする方法などはありますか?
説明が下手で申し訳ございませんが少しでも気づいたことなどがあれば教えてください。
(1,974 Views)
You can set x0 and dx of the x axis. No need for any data manipulation.
(Also note that all controls and most of the early math should be before the loop.)
(1,958 Views)
Accepted by Hiddg
Simplified example:
(1,948 Views)
Thank you from the bottom of my heart!!!!
(1,898 Views)
As has been said here, you can also avoid that property node.
Also, if dx never changes at runtime, you can also set it directly in the graph properties dialog:
(Only do that if you wire the array directly. don't do it if you do the cluster or waveform option above)
(1,860 Views)
thank you!!!!
it was successfully resolved!!
(1,853 Views)
